Ball lift motor stopped
  • Ball lift motor stopped
    Leave it to me to have a problem like this. I had a ball lift stop today. Did not overheat. I thought well it must've gone bad. Took the motor in back works fine . Installed in another lift works fine . Put new motor in the original problem lift still doesn't work. This motor also checked out good in the back.
    Heres where it gets weird .I believe the ball lift control box is a frameworx . It has two cube relays and a transformer . power in on the line side 115 volts power out 115v line 115v common. The motor is 110 why would both lines be hot on the output side? Oh I put in the spare box we have and it has the same readings. HELP
    Did you check the control box in the back?
      Is the blower motor running? Could be a bad safety switch.
        No blower is not running. I have this control box plugged in to a 115 volt wall outlet on a bench ny itself . When I close the contacts manually I still have115v to hot to ground and neutral to ground. 0v between neutral and hot.
          What machine is it hooked up to ? Sounds like the problem is in a relay. On my A2's, there's a circuit in the electrical panel to run the controller for the powerlift. On my 82/70's, the M1 relay in the chassis runs the powerlift. If all the hardware checks out, it's a relay problem...
          "Don't expect too much and you'll never be let down..."
            I think the relay is wired differently than you expect. Both sets of contacts are switching the hot. You can leave it that way and run the neutral around it if you want. The neutral doesn't need to be switched on and off.
              Take a look at this. It might help.
              Brunswick power lift
              Edited to add:
              I just this summer replaced all of our old B2000 lift and lift boxes with the Frameworks stuff but put in our relays and bases. Eventually all of the MS and TDM's will be replaced with the same realy.
                Not trying to highjack the thread but, do the Brunswick lifts not run on 110? in the diagrams of the other thread they are 230/240 line in. Also why would you switch the hot on both sets of contacts?
                  Some do run on 120 volts. Some of the diagrams are for 208 or 240 volt accelerators or boosters. Running one wire through both sets of contacts on a double pole relay splits the load so each set does half the work. The contacts are supposed to last longer.
                    I personally have both. Original 32 lanes are all 110. The 12 lanes that were added later run 220. All of them have 24v fan motors.
                      that makes sense at 230/240V but I was thinking in the 110/115 frame of mind. Thanks for the answers, the 24v fan now explains what the transformer does too.
                      Pins getting gouged
