Soda Machine Lock
  • Soda Machine Lock
    Anyone have experience opening vending machine doors controlled with key fob and no physical lock?
    What do you need to know?
      Electronic lock motor is not responding to open door. New/old FOB with or without extra battery pack bypass -- still no response.
      Either the lock CPU thing is kapoot or disco'd from last time someone was in there.....anyway, is there a way to get?
        I think you'll need to find out who made the machine and contact them. Maybe if you unplug the machine for a certain amount of time and plug it back in it will reset the lock. Maybe pushing the numbers on the front in the proper sequence will open it but only the manufacturer would know that sequence.
          If its not your machine, call the bottler who does own it.
          Sounds like a Triteq lock.
          Maybe try that website first?
            I have been in contact with the Triteq folks and am waiting on a response. If there is a code, they should have one. Problem would be if it's a case of the lock motor bad or control board bad not sure what their actions are.
            Am just curious if there were anyone else that had ran into this problem. It's our machine, so the other alternative is to have a maintenance service call by someone to cut the door off or something i guess....but if it comes to that, I'd rather be the one destroying it.
            MONITOR COLOR ISSUE!!
            Oil in gutters
            C1 Pinout drawing
            Finished the C1 drawing.
            Thanks Felix.
            If you see any...
