arachnid dart board company
  • arachnid dart board company
    Is arachnid dartboard company out of buisness? My friend is having trouble with his dart board and I tried helping him but the website does not come up. Also if anyone knows anything about these dart boards let me know. Thanks!
    Alex
    The mini machines are almost done! http://www.bowltech.com/forums/impor...e2012/grin.gif
    Re: arachnid dart board company
    Alex, Arachnid is no longer making home models. That business is handled by dmi sports. www.dmisports.com
    You can find arachinid here www.arachnidinc.com
    What is the model # of the dart board in question?Also , what is the problem with it?
      So dmi sports is making the home models now? I will have to email him to find out the exact model # but the problem is that when he starts it up it gives him some type of error code and we are unsure how to fix it. I can see if I can get him to send me a clearer picture. I have a picture but it is not very clear and you almost can read it.
        Alex
        You could try removing the little coin battery on the logic bd. Check to make sure it is good while you have it out. Reinstall the coin battery and pwr back up. It resets parameters on the logic bd, sometimes the ram memory gets garbage in it and this generally removes it. Good Luck!
        jimmy
        jimmy
        <span style="font-weight: bold">Dellamano Electronics Repair</span>
        k&#121;&#98;d&#64;&#99;h&#97;&#114;t&#101;&#114;.& #110;&#101;t
          Have you checked for broken dart tips in the dartboard holes that may be holding one or more switch contacts closed on the switch matrix ? Also any board segments that may be holding switch contacts closed on the matrix.
          Broken key
          Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
          Anyone wanting to have a guess at
          A) Which...
          MONITOR COLOR ISSUE!!
          Pin spot is off
          4" PVC BOW EXTENDERS
          As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
