Double Up "Winner Every Time" By Smart ind.
  • Double Up "Winner Every Time" By Smart ind.
    hey guys,
    I don't know how to get this Claw tighter there is a single dial on the main board which Tightens both claws i have at the highest tightness but its still not working the stuffy side is great but the Candy side will not pick up candy for nothing! i seen kids play for like 20 mins before they get a single Candy. any ideas would be Great.
    Tony S
    Splitsville Entertainment
    82-70 Machines
    Brunswick Frameworx scoring
    First, lube the claw assembly. Sticky claw links can cause a poor grip.
    Second, check the voltage at the claw. Sounds like it could be a poor connection.
    Lastly, the adjuster pot could be bad. Digikey sells replacements if your handy with a solder iron.
    PinCup
      Hey Tony,
      1. Try checking the voltage at the claw - should be roughly between 30-50VDC if i remember correctly.
      2. There should be more than one dial - usually inside the coin door there is adjustment for strength. Failing that there should be that adjustment dial and also a programmable setting. Most of the "Winner Every Time" machines i have worked on have both dials and programmable adjustments - of which both must be done.
      Are you sure the dial controls both claws? usually these dials only correspond to one of the claws- not both.
      If you could attach attach a picture of the game so im 100% sure which machine this is (As there are many different "Winner Every Time" machines) id be more than happy to give you more help if required.
      Jake
      Table support assembly
      Foul Light LED Mod
