Coil cleaners, the best?
  • Coil cleaners, the best?
    I was wondering what you guys, that clean the coils in your kitchen/bar equipment, use to clean the coils with? Do you use a "no rinse" cleaner or some other chemical? Mine all have typical "dusty" dirt that I was able to get some of with just hot water in a spray bottle. Our upright frezer in the kitchen has "greasy" dirt that i had to use a straight degreaser then spray with water to get a little clean. Do you use the same cleaners on your air handler coils as well? thanks for your input guys.
    Alex
    Cloth: ShamWow!
    Machine: Johnny 5
    Re: Coil cleaners, the best?
    Hi shamefowjze, I use Blast-A-Coil to clean the tougher dirt and grime, ie. anything around deep fryers where grease gets in the coils. Grainger has it but it's expensive. $9 a can. One can is good for 2 or 3 coils.
      I use Blast-A-Coil also. Seems to do a pretty good job.
      Pete
        Hi pressure nitrogen works well also if you want to stay away from chemicals. But Blast-A-Coil is best. Gets things nice and clean and you don't have dust flying around when everything is said and done... [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
          I forgot to mention the stuff smells pretty too, if you're not the one using it! It's kind of like Simple Green, smells good in really small dosages. If your dirt is dry, a shortened paint brush will rake the dust off no chemicals needed. But it would be a good idea to clean them with a coil cleaner every second or third time. Good luck.
            On greasy Kitchen coils. Use Grease Lightning and the Hottest water you can find. That snack bar grease is tough stuff to get off coils.
            As far as AC coils , Use a non acid Coil cleaner (Heavy Foaming)and rinse with a hose. I dont recommend No rinse coil cleaner.
            MASTER HVAC Tech
              For our smaller cooler coils, I just take a wire brush and pull them main stuff off the front (fan off) brushing with the coils. Then with the fan on I blow it out with a spray dust can. Gets a little dusty, but they turn out nice and clean.
                Using a nylon brush would work better than a wire one, wire could be bad for the coils. If you are looking for a cheap way to clean them just a heavy duty degreaser will work fine with a nylon brush.
                Matthew Knightly
                Thomas College
                Waterville, ME
                Sparetime Recreation
                Pro Shop/Mechanic
                Waterville, ME
                  i only reccomend using liquid nitrogen or blast a coil both do a good job
                  • ElCheapo
                    What do you find works best?
                    by ElCheapo
                    I have Brunswick Pro Lanes that are not even a year old. what is the best way to get chocolate off the approach. i had a youth tournament and someone dropped a candy bar on the...
                    05-20-2007, 11:53 AM
                  • RenoScrub
                    Clean Green Carpets
                    by RenoScrub
                    I have recently installed 4 splawn clean greens and will install for all 21 lanes, and I am searching for the best methods of cleaning. At the moment we are cleaning them 2 times...
                    10-25-2013, 12:39 PM
                  • Tony Tiger
                    Fizzion
                    by Tony Tiger
                    OK so I leave the extra cleaner in a bucket for a couple of days and I get this white cloudy look to the water and this thick sluggy slime buildup in the bottom of the bucket....
                    01-15-2007, 05:04 PM
                  • Beaver6440
                    Cleaning turnpans
                    by Beaver6440
                    Hi guys,
                    I know this subject has probably been takled about in the past, but I could not find any info. What are you using to clean your turnpans with. We have been wiping...
                    12-17-2008, 12:32 PM
                  • 8270king
                    Coil Cleaning
                    by 8270king
                    Once the cottonwood subsides for the year - I clean the HVAC coils.
                    I use a soft whisk broom to get the cottonwood off the coils. Then I use a leaf blower to get...
                    06-07-2013, 11:10 AM
                  MONITOR COLOR ISSUE!!
                  Pin spot is off
