Coil Cleaning
  • Coil Cleaning
    Once the cottonwood subsides for the year - I clean the HVAC coils.
    I use a soft whisk broom to get the cottonwood off the coils. Then I use a leaf blower to get rod of the clumps. I have already had to blow the cottonwood off once this year already.
    A garden hose works well too. Just be careful not to use too much pressure as some of the newer coils are not that strong and will get mashed down. I also use a mild foaming condenser cleaner to get deep down in between the fins.
      King, consider making a screen cover over the coils, one you can remove and clean. It helps tremendously!
      Or consider killing the near by culprit cottonwood tree! I do recommend one over the other!
      For the record, I am a tree hugger!
        By the way, Nice work!
          Thanks - so many cottonwood here - a screen/filter would be useless.
          I use the foaming coil cleaner too!
          Thanks!
          MONITOR COLOR ISSUE!!
          Pin spot is off
