Double ball lift for extra wide pair of l
  • Double ball lift for extra wide pair of l
    i have a pair of lanes with posts between so have a set of rails to get ball to opposite lane return but no paddle so pins always falling out between machines and pins blocking ball...it was suggested I add a second ball lift and funnel ball over at top over to other downsweep,has anybody out there done this and can share ideas or pictures on steering the ball over?thanks
    There was a post here somewhere here that had a "switch track" at the top of 2 seperated ball lifts on the forum.
      This isnt the post, but will give you some ideas if you are still thinking about a switch track.
      https://youtu.be/Pd_FCW77bxY
      MONITOR COLOR ISSUE!!
      Pin spot is off
