Paint Front BR Hoods??
  • Paint Front BR Hoods??
    I just purchased used Frameworx hoods and Trays. Hoods Peeling clear coat? Sand and new clear coat? Imron paint Black? Rhino Liner spray? NJ Carolier Lanes put thick rough spray on hoods and someone said it might be Rhino liner used for pick-up truck beds.
    Find a person in a local body shop who is knowledgeable about fixing Corvettes, they will be able to help you
      Back in the 70's we painted our hoods with Imron. First we put on a dust coat of Zinc Cromate which is what was required back then to bond paint properly to fiberglass. Don't know if that is required anymore. It wore like Iron. Even the biggest bowler could Not "kick" through it.
        Thank You guys for the info.
        • Marty Murphy
          New hoods and racks
          by Marty Murphy
          Looking at new hoods and racks for our B2000 lifts. I have installed frameworks hoods and racks before, like the look and the colors. Am looking at Murreys hoods and racks now,...
          03-31-2010, 08:52 AM
        • 1mechanic1
          Racks and hoods
          by 1mechanic1
          We are considering new or used racks and hoods for our center. I would like some input on your opinion of different models. We have Brunswick power lifts. I am not interested...
          12-30-2005, 06:30 AM
        MONITOR COLOR ISSUE!!
        Pin spot is off
