Ball Lift
  • Ball Lift
    I have a ball lift that always seems to get jammed during practice and practice only. Take the hood off and there will be 3-4 balls caught. I have to manually accelerate them to the racks. But, during the rest of league play and during open play, it works perfectly. Any Ideas?
    Re: Ball Lift
    Check the contacts as they may be going out, there should be two in there one for each lane. If one is out the lift won't come on until both machines are on and could be the problem.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
      Re: Ball Lift
      Those are both good. The balls just get jammed and the motor shuts off due to over load. Have to manually unjam then press the thermoverload button on the motor. It works perfectly any other time then during a five man league warm up.
        Re: Ball Lift
        Take a look at your preferance system to be sure it works properly. Getting a few balls locked on the even lane then released will send them up front at the same time, one behind the other and cause this.
        Marty - Liberty Lanes
        56 Jap A-2's Qubica VDB's
        2 Kustodian Walkers
          Re: Ball Lift
          The ball tracks might also have a "flat spot" on them, that will also cause a ball or Balls to be caught when they decide to come up at the same time.
          <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
            Re: Ball Lift
            Maybe your motor is going south, As soon as its powered up, it trips overload, and the balls get stuck because its not running.
            Mike
              Re: Ball Lift
              Do a two ball test...put 2 balls at front of lift and push them up at same time. Observe lift and see if it can handle the load.
              What type of ball lift control box do you have?
              Peanut
                Re: Ball Lift
                we had a pair do that about a month ago. turns out the pulley on the motor had the grooves worn down. changed the pulley haven't had a call since.
                mike d
                  Re: Ball Lift
                  make sure the belt is tight enough and clutch isnt slipping also I'd say good possibility the preferance system isnt working right or balls yoyoing and then coming back more than one at a time.
                    Re: Ball Lift
                    I have this same problem, but when I go to manually turn the pulleys to get the balls out, the balls come out REALLY hard. Most of the time, it manages to bring the motor to a stop without tripping the overload. Balls are getting caught right between the top and bottom tracks. I do know that it is not a preference issue, as it has happened with only one lane on in open play.
                      Re: Ball Lift
                      Thebuch, there's a few of things that may cause this.
                      - Upper or lower wheels cracked or worn
                      - Poor belt tension
                      - Poor belt condition
                      - Worn clutch
                      What upper and lower wheels does it have?
                      Does it have a 'V' or poly V belt?
                      What traction material is used on the 'C' tracks? Colour?
                      Do you use a retarder?
                      Qubica BES-X Lane Advertising
                      Ball Damage at my wits end
                      GS-X table bolts/stud
                      Other that...
