"Tablejam changes a distributor belt"
  • "Tablejam changes a distributor belt"
    My first video upload in awhile.
    I thought it would be fun to see me changing a distributor belt.
    This machine had a waffle belt on it but started having frequent, random jams. Turns out the belt domed in the middle so it wasn't grabbing the pins like it should have, causing them to hesitate and jam. The new belt is a CNC poly V.
    I thought for sure the belt wouldn't turn when you turned on the BE motor. No belt guards?
    There! Try to NOT work now!
      Not here, never had them in this house
        If you pick up on the belt, and push down on the spring bracket, you don't have to take the spring off.
          That spring is pretty easy for me to deal with, as you see in the video. Plus with the spring off I can check the tensioner assembly.
            damn, was hoping those belts would last a lot longer.
              Tried similar belts quite a few years ago, and had the same issues. I was hoping they had fixed that too...Hmm, guess not. Still love the lime green belts from A1.
                Always a good idea to buy a few items that you think would be great and test them for at least 6 months, before you spend a boat load of money on something that fails. To all the noobs whom are working on any machines.
                - Albert Einstein
                  Is the yellow belt riser not needed anymore ?
                    TJ, how old was your waffle belt? I have a few with curved belts , but having the Tuffy jam stoppers they don't cause an issue.
                      Going on about 3 years now.
                        I have them and a few causing problems and when they pin jam, it's like a car pile up on interstate. But they do well on rest. I'm going to put other belts on, but don't which ones would do. I had the poly grooves which did very well. Any suggestions?
                        IT'S CARNIVAL TIME!!!
                          What kind of clutches you use t.j. just wondering
                            A mix of oem and roller
                            Testing Link Belting "PowerTwist Drive"
                            Recently got my hands onto some meters of these: http://www.fennerdrives.com/powertwi...Drive-A/13/4L/
                            At first let me tell you that they are pretty sturdy and very...
                            Ion buffer brush
                            Have Kegel ion model B. Noticed the buffer brush rubbing up against the felt that's attached to the oil transfer assembly (the "door" you open to fill the tanks). This...
                            Foul Light LED Mod
