Off spot switch
  • Off spot switch
    Where is my off spot switch at so I can adjust it so I don't have to keep hitting reverse sweet
    You can't adjust it enough to make a difference. But you can pull one wire off the switch. But then you'll never have an O.S. cycle.
    It's mounted to the lever, behind the Yolk Weldment, behind the Table Drive.
    There! Try to NOT work now!
    Table support assembly
    Foul Light LED Mod
