sweep likes to backup at 270
  • sweep likes to backup at 270
    as machine goes to set a new deck the sweep will sometimes back up far enough at 270 to pull off the sweep cam switch to where it will not cycle up you have to un plug and turn sweep forward to get it to return to 0
    If the sweep is "backing up" at 270, isn't that a sweep-motor coasting issue?
    There! Try to NOT work now!
    Pins getting gouged
