No pins after strike
  • No pins after strike
    One of my machines will not set a new rack after a strike is thrown. It will however set a new rack after a second ball is thrown. What can I try?
    Whoops, AMF forum.
    Look for a broken wire/grounded respot cell.
    Last edited by Wookie8662; 03-11-2018, 04:27 PM. Reason: erase detector rod comment
      what type of chassis?
      In search of the C2B plug
        Check your respot cells for wires and the set screw gap as well
        Experience: We currently maintain 12 AMF 82-70's
          Is the lane scoring correctly? What scoring system and cameras do you have?
            Sounds like the clock, data, ground signal is not getting to the chassis for the strike cycle.
            The New Brunswick NXT
