Table stops half way down when respoting pins.
  • Table stops half way down when respoting pins.
    Runs great when setting full rack. And when it's picking up pins. Just when it setting them down. Most times it jerks at that spot, but sets them down, but sometimes it gets stuck. And I can't get it to run with cam switch. Have to manually. And sweep stays in guard till table is about half way up
    Next time it does it, see if SC and TB are both open at the same time. It could be that the sweep is starting a little late from first guard causing an interlock. ???
    There! Try to NOT work now!
      Ty. Was the problem. Little adjustment on TB.
        Yw. Ya gotta love the easy ones!
        Detector Rod Adjustment
        The New Brunswick NXT
