90XLi MCU installation
  • 90XLi MCU installation
    Hi Guys,
    I’m helping at an install and can’t recall how to connect the MCU for the first XLi chassis. We are running 70XLi’s with Accuscore + scoring. Where does the home run cable go to? Does that go to the front desk? And what cable goesnfromnteb MCU in the workshop to the first XLi chassis?
    I was wondering is there an installation diagram somewhere of how these are hooked up?
    Regards,
    Brett
    AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
    Usually the MCU is located at the front desk, and will have an adapter box to connect to the desk computer.
    The homerun cable normally goes from the first chassis (lanes 1/2) to the front desk where the MCU is located.
    If the MCU is going to be in the workshop, then thats where the homerun cable should go.
    This is for a Vector Plus install. Accuscore may be different.
      The installation manual part number is 400-088-051
        Here, the MCU is a stand alone unit. The "out" cable (Home Run) of the MCU goes directly to the "MCU in" of Chassis 1&2. "MCU out" of that chassis connects to the rest of the chassis' via daisy chains.
        There! Try to NOT work now!
          What I’m confused about is the home run cable has an RJ45 socket on both ends, while I get that is what connects to the mcu how is that going to connect to the chassis? Is there another cable that converts RJ45 to serial?
            Either that, or it's not the correct home-run cable to suit that purpose.
              The only reason I assume there must be a converter cable is at my home venue in Sydney I have 1 cable coming from the MCU which has an RJ45 plug so what converts that to serial plug?
              And im currently in Brisbane helping on an install so I can’t have a “quick look” to see what my centre has.
                The one install I did had a premade cable, with an RJ45 at one end, and a DB9 plug on the other end.
                Contact AMF and see if you can use a regular adapter on the chassis side of the cable.
                  The RJ45 home run cable plugs into the A on the bottom of the mcu. I’ll send you a pic of it tomorrow morning.
                  Peter
                    It is not an RJ45, it's called an SDL connector. SDL connectors aren't made any more.The cable goes from the MCU output to the first pinspotter chassis.then, daisy chained to the last pair, ending with a terminator in the last chassis. You can find a cable with an SDL connector and splice into it on the MCU side, and use a DB9 extension cable for the other end. It only uses 4 of the 9 wires. TX + and - and RX + and -.
                    This post is not an unpaid promotion of my business.
                      Is there is an official QAMF part number for the cable ( or converter cable) that goes from the 1/2 XLi chassis to the MCU?
                        If the MCU you're installing is the USB version, the home run cable is 088000510. Installation instructions are on the portal, look for PN 400088051. If it is an older MCU, the HR cable PN is 088000104. It has a DB 9 plug on the pinspotter end and aan RJ-45 on the MCU end
                        Regards,
                        Billy T
                        [email protected]
                          Awesome thanks Billy, yeah sadly we have the older MCU, I’d love the USB MCU.
                            Turns out they never sent us the cable that goes from the XLi chassis to the MCU, so I have an MCU that was cut by someone at the venue the stuff came from due to the installation they had. So the wires that come from the cable are orange/white, orange, brown/white, brown. How do they go into the RJ 45 plug ?
                              I'm not sure if this will help you any, but I have, looking at the back of the plug from right to left: WH-BK-Space-WH-BU. There is also another Home Run that's not being used, but has the same configuration: GR-RD-Space-BK-YL.
                              Bind in deck hook linkage
                              I'm having a problem with the deck holding hook lifting up and not engaging the pin during 2nd ball cycle. At first, I thought it was the detector but have ruled that out. If...
                              GS-X table bolts/stud
                              I know I'm not the only one who has had the table bolts literally shear off. I cannot explain where there would be a force strong enough to do this to the bolts.
                              Other that...
                              Not scoring when ball speed "ball detection" is enabled
                              I have a pair that won't score if ball detection is turned on, but when I turn it off the scoring works right away.
                              On the ball speed sensor, the green light indicates...
                              GSX pins dumping in table at front
                              Hi everybody, I'm looking for some guidance. My GSX machines have a problem with pins gathering in the table in front of the #3 pinholder. One or two lanes are worse than the...
                              Idler shaft
                              One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
