Adding a Strike Light on 82-90XL
  • Adding a Strike Light on 82-90XL
    We have 82-90XLs, Qubica BES-X and our masks are the typical modern black frame style which only have lamps for ball 1/2. I'm toying with the idea of adding a strike light. Is it simply a matter of tapping into the mask connections on the front end box? Our FEBs are AMF 090-005-765 which is the strike/foul model according to the chassis manual.
    My plan was to create a custom DB9 cable that acts as a pass-through for the ball 1/2 signal to the mask, and also breaks out the strike signal so I can connect it to a custom fixture - an X-shaped array of LEDs or similar.
Oil in gutters
C1 Pinout drawing
Finished the C1 drawing.
Thanks Felix.
If you see any...
