Here's a good one!
  • Here's a good one!
    I am running into a problem with two of my lanes here, don't rightly know what is going on, little help!!. What is going on is the two lanes are running in sequence, you hit the ten pin reset and both lanes run cycle at the same time? does not matter what lane you reset, they run togather. We have the vector scoring system which is in sad shape to say the least. Made checks of the camera board, reset buttons and wires, at a loss. Little help please.
    Sounds like it can be a bad CPU board
      Do you mean in the server of the scoring system?
      MONITOR COLOR ISSUE!!
      Pin spot is off
