8270 pin setter problem
  • 8270 pin setter problem
    Can anyone help with a sweep drifting and causing an interlock.
    The most common issue with sweep coasting is burned C1 (machine side) sockets. Have you checked them and if so what method did you use?
    There! Try to NOT work now!
      Check the stator on the motor. Bad switch or loose gearbox maybe
      IT'S CARNIVAL TIME!!!
        A few things.
        What motor start switches and motors do you have on your machines?
        What chassis do you have on your machines?
        Drifting can be caused by burnt pins in the C1 harness machine and chassis side, a fried sweep contactor in the chassis, a busted centrifugal switch or fried boards in the stator if you still use them, a bad motor start switch or a bad gear box. Easiest way to find the problems for beginners is to swap parts with other machines until the problem follows.
        - Albert Einstein
          You have two threads going on this topic. I would suggest letting this one die and continuing with the original post.
          http://www.bowltech.com/forum/pinset...em#post1086497
          Oil in gutters
          C1 Pinout drawing
          Finished the C1 drawing.
          Thanks Felix.
          If you see any...
