self repair of xli chassis
  • larszszszszsz
    started a topic self repair of xli chassis
    hej, fellow mechanics,
    Wondering if anybody know how to repair a chassis. Got 2 broken ones.
    Its is 100% the chassis and the encoder,cable etcetra.
    chassis 1: does not send out a signal the the powerlift to start.
    chassis 2: signal to the brake of the sweepmotor is random. (timing is off)
    Just to be clear... problem is IN the chassis and wondering if someone knows what to replace.
    Thanks Lars
  • Bill LeMieux
    I don't know the answer to the first question, but as for the second: It could be that the male and female connections are just loose. Use a small screwdriver to spread apart the male pins on the chassis connector for the sweep break. I say this because I had that issue twice and that remedy cured the problem. But that is if it's a random issue. If it's constant, then replace the appropriate relay shown in the accompanying photo.
Preventative Maintenance Brunswick A Jets A2 - Pin Light Conversion
Rear Wall House was having a big problem with the pin lights. The ends were pretty much worn out from the vibration so duct tape, electrical tape and jiggling the light would...
Detector Rod Adjustment
I am currently doing my first detector rod adjustment. The first thing the book tells you to do is adjust the gap between the oor controller and the blocking surface on the detector...
The New Brunswick NXT
Best Pinsetter on the market today
Distributor Repair Kit
Has anyone installed a dist. repair kit ? Wanted to know if its a fix to the problem or just a brunswick brand Band-Aid....
Preventative Maintenance - Brunswick A, Jets, A2 - Wiring Problems
Had to do a service call at a friend's center as he was out of town. Seems Accelerator on 5 & 6 had quit. Breaker, (which fed 3 pairs), had not tripped, ohm check on motor...
