Carpet belt climbes over the front roller
  • Carpet belt climbes over the front roller
    I have a problem with my carpet crawling over the edge of the front roller on the ball door side.
    It´s a brand new carpet, I have changed the supports on both sides.
    Is it too much tension on one side or is the bounce plate to high ?
    Any suggestions ?
    Feels crap to destroy a new carpet.
    Have you flipped or replaced the frontoller?
      Did you replace the front roller bracket springs?
        Arrow on carpet ? Arrow should point to the rear
          Yes, I flipped the front roller, The Carpet belt arrow is ok but i will try to replace the bracket springs.
          Maybe i shall also check the front roller and see if that is ok.
          Thank You so far.
            Rear roller bearing/bearing support worn , shifted , or missing ?
              If you don't find anything obvious, Stahl's has a cone spring to pull the carpet away. Did you have any problems before? and what carpet and what parts were changed?
                Thank You guys.
                I fixed it last night, probobly the front roller but i changed all the parts so now its all fresh.
                Great forum for help, really thankful !
                Have a great day from Sweden
                  Thanks for letting us know how you got on.
                    Glad you got it fixed. I have had front roller bracket spring problems that have caused that. Always a good place to check when having this issue.
                    Oil in gutters
                    C1 Pinout drawing
                    Finished the C1 drawing.
                    Thanks Felix.
                    If you see any...
