82-70 Burning Relays
  • 82-70 Burning Relays
    We have one lane that keeps burning up relays on the MP Chassis. Head mechanic said he checked wiring and everything else seems to be fine. This lane used to have an old brown Zot Chassis on it but it decided to go out one day. Please help!
    Which relays are you burning out? What is burning out, the coil or the contacts? How often are they burning out?
      Do you have the wrong voltage running to the coil?
      Experience: We currently maintain 12 AMF 82-70's
      Broken key
      Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
      Anyone wanting to have a guess at
      A) Which...
      MONITOR COLOR ISSUE!!
      Pin spot is off
      4" PVC BOW EXTENDERS
      As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
