() silver chassis question.
  • () silver chassis question.
    There are 2 capacitors per side in the chassis. What are these for? The motors have there own capacitor which I assume is their start cap. As the motors have a brake system attached to the shaft do they use the capacitor regenerative braking as well?
    Regards,
    Len.
Detector Rod Adjustment
The New Brunswick NXT
