ball light
  • ball light
    What controls the switching of first ball second ball light
    TA2 I believe
      I assume this is related to your other post regarding machine staying on first ball? It's going to depend on which chassis you are using. If you are using a 5 board chassis then there is memory circuitry on board 3 that remembers which ball it is on and accordingly controls the 1/2 ball lights. On the MP chassis it is micro processor based and has on board memory to handle this. There isn't an external control item in either case.
      I'd suggest swapping the board or the entire chassis with another lane and see if the problem follows the chassis. I'm sure it probably will.
      Which chassis are you working with?
      Detector Rod Adjustment
      The New Brunswick NXT
