82-90xl Silver Chassis Relays
  • 82-90xl Silver Chassis Relays
    Can someone tell me the purpose of solid state relays K5 through K8 on the "small" silver 82-90xl chassis?
    I believe 2 of them control the pit lights for odd and even lanes. But which?
    Is there a schematic for this chassis available somewhere? We have piles of these chassis here in the back, a few of them seem to have only minor issues that I would like to fix in-house.
    Try going on to the QAMF portal and downloading the chassis manual.
    Peter
      I don't think they want people digging around in these by themselves anymore so they don't publish the schematics for them. At least I've never found one and there have been others on here searching as well with apparently no success. I, of course, feel that if you own the equipment, you have the right to fix it so I don't agree with this policy. But if you find the schematic, please let me know.
      None the less, you have working chassis so a little investigative work should net you the results. At the very least you should be able to feel when a relay turns on so when you turn one light on you should feel one relay click and when you turn the other on, the other relay should click. If you can't feel them you could take voltage measurements at the relay contacts or trace them to the terminating points.
      Let me know if you need help tracing these out.
        All they want us to change on the chassis is the fuses for the spot solenoid and the pit light. Not to mention the premium the sting you for the fuse itself
        Peter
          We don't have the schematics for any later model chassis. What you do with a chassis once it's out of warranty is up to you.
          Regards,
          Billy T
          bthompson@qubicaamf.us
            Pull one out and see what doesn't come on.
              If I'm following the discussion correctly, the relays in question (K5-K8) are the ones that reside on the main PC board inside the chassis?? I had a chassis fry one of these relays but fortunately had some spares laying around. They simply plug right into the board (I learned this the hard way) and are held in place by a small plate.
              Will try to remember tomorrow and see if I can get the proper numbers for the part.
              -- Larry
                Finally found the bag those relays were in....
                Part number is 755-520-074, Relay 1.5A - High Surge
                Whether or not QAMF has this item available directly is the question.
                The relay itself is Crydom CY5688
                Crydom is now known as Sensata Technologies. So some digging may be needed to find an up to date part number.
                -- Larry
                  Give QAMF a shout the part number should be cross referenced. That’s if they still stick it
                    This is still a good part number, but there are currently none in stock
                    Regards,
                    Billy T
                    Oil in gutters
                    C1 Pinout drawing
                    Finished the C1 drawing.
                    Thanks Felix.
                    If you see any...
