Sweep Coasting
  • Sweep Coasting
    I have a Westinghouse combo motor that is coasting... a lot. I checked the resistors in the wire channel and they're fine, I replaced the capacitors as the previous mechanic put ones in it that were too big, and I swapped the motor with another one and it got a little better but not a ton. Ideas?
    Experience: We currently maintain 12 AMF 82-70's
    Mechanical or solid state switch on the stator or contactor in the SS/MP chassis. Most times it's the contactor especially if they ore old. Larger capacitors are generally ok, but not smaller ones...
      Solid state on the motor. Part 610-309-044
        So you swapped motors, gearbox as well? So is it a head, gearbox or machine problem?
        Manufacturers of idiot proof products often underestimate the ingenuity of idiots!
          We did not swap the gearbox. Haven't looked at the coasting issue in a while. Will probably change out the gearbox this weekend.
            I would hazard a guess to say your gearbox is slack and needs rebuilding hey.
              The SS switches are notorious for causing motor coast.
                Have you tried swapping the chassis to see if it's a switch board problem? Also ohm out the windings in the motor. For a Westinghouse you should read about 4.7 & 1.9 ohms.
                I had one set of windings measuring 4.7 & 4.8 ohms, and on a sweep it would coast a good 4-5 seconds past where it should stop.
                  I've found that, most often, if you have a sweep coast issue its in the chassis sweep/table relay (Braking circuit). Sometimes it's the pegs on the C1 plug row 4 (top) and/or the associated start coil pegs in row 2. They get burnt out due to too much amperage.
                  MONITOR COLOR ISSUE!!
                  Oil in gutters
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
