M.P. CHASSIS
  • M.P. CHASSIS
    Problem is throw 1 st ball sweep comes down no table run. If u hit program zero then table goes down to 2nd ball .
    Changed ALL Switches on back box pit table sweep power tried known working chassis same problem. table won't run after 1st ball or even strike table runs when u manually do through contacts. Help Please Thanks
    Fixed A.M.F sweep motor drifting i hate these motors they drift after 3 months bad that's what made me think of that activating sweep switch telling it interlock adjusted screw way out been running fine. Will see Thanks
    Oil in gutters
    C1 Pinout drawing
    Finished the C1 drawing.
    Thanks Felix.
    If you see any...
