82/70 won't program...
  • 82/70 won't program...
    The pinsetter won't program through the MP chassis..The chassis will program through the pbz.but the pinsetter wont ( only back end motor comes on)..I can run sweep and table through chassis push button switches,also can run sweep through the sweep run switch...Cannot run sweep or table through SA or TA..The chassis and sweep cam switches have been replaced still same issue (pinsetter won't program)...problem solve...Power switch wire from rear control panel shorted out in wireway on its way to 5 and 6 in the A&MC box
    Is the lane in instructomat?
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
