090003076 vs 090003077 orientor pan
  • 090003076 vs 090003077 orientor pan
    Anyone know what the differences are between these two part numbers other than the ~10% difference in cost? Both are shiny zinc plated. 090003076 has a shorter description on the Qubica web site and doesn't include 70s in the compatibility list. We're running 90XLs.
    I can only find the 077 on the QAMF portal. I even went on the 70’s page and the o pan is listed as 090003077. But I could be wrong also. I’ve never know the o pans from changing much over time apart from aftermarket products
      Maybe it's not available internationally for some reason.
      https://eshop.qubicaamf.com/webapp/w.../wcs-090003076
      https://eshop.qubicaamf.com/webapp/w.../wcs-090003077
        The 3077 has the sound deadening on it. I don't believe the 3076 should be available for sale as it's not a finished part
        Regards,
        Billy T
        [email protected]
        MONITOR COLOR ISSUE!!
        Pin spot is off
