Westinghouse combo rebuild
  • Westinghouse combo rebuild
    Who rewinds Westinghouse combo motors? I know Stahls does but I dont want their relay on these. I have them in my wireway already.
    You could always contact QAMF, as they may have a motor repair program. Or you could look up a local motor rewind shop and take it in to them to see if they can repair it?
      We don't repair motors.
      Regards,
      Billy T
      [email protected]
        Just call Stahl's and ask them to not install the relay. They really do it right, and cheaper and quicker than local shops can.
        When I get one of their rebuilds I just remove the relay. Then I put it in the spare parts bin. Basically a free spare relay.
          Local motor shop wants more than double stahls price.
          The only way stahls will do it is with the relay. Problem is that I already have their relays built into my wireway so then I have 2 on the same line. Looks like I will have to bypass it.
          MONITOR COLOR ISSUE!!
          Pin spot is off
