1st/2nd ball light
  • 1st/2nd ball light
    I have a machine that intermittently will glitch during a cycle.
    Scenario 1. I watched the bowler throw their 1st ball, machine ran sweep to 1st gaurd, table runs and picks up pins, sweep runs through to 2nd gaurd, table respots pins, as sweep and table run home 2nd ball light comes on for a second and goes back off. Bowler throws 2nd ball and machine completes normal 1st ball cycle and is now on second ball with standing pins. Scoring worked fine, but next bowler has to push the ball return cycle.
    Scenario 2. I watched bowler throw 1st ball and normal 1st ball cycle. Bowler throws 2nd ball and normal 2nd ball cycle but after spotting pins machine does not switch to 1st ball. 2nd bowler bowls 1st ball on the lane, but machine is on 2nd ball. Machine completes normal 2nd ball cycle, so lane did not score and a respot is required.
    This seems to happen at random and not very often but does anyone know where i can start looking?
    What version of pinspotter?
      IIRC.... On the 82/70ss I used to be able to trick the solid state chassis into shifting ball cycles by flicking the TA1 and SA switches simultaneously. If he's got the solid state chassis there might be a little bounce in the cam switches.
      -- Larry
        Are all the pins ok on the PM plug both machine and plug sides. If you shift the chassis does the issue move with it?
          Amf 8270 with solid state chassis
          ill try swapping chassis to see if it stays on the lane or follows chassis
            After swapping the chassis the problem did not follow the chassis or stay with the lane.The green plug may have been a little loose or had a bad connection.
            Does anyone know where I can get the tool and pins to replace the pins in the green plug?
              Sometimes it just needs a wiggle. On the 15 years I worked on SS chassis I never needed to replace a single pin. Glad you fixed the issue.
              Peter
                It's been nearly 25 years since I last repaired an ELCO connector,
                QAMF may still have the pins available but Billy will have to answer that one.
                IIRC..... ELCO connectors however use the same fork shaped pin on both sides of the connection. Think of it as two forks joined together with one rotated 90 degrees to the other. Over time the fork end of those pins get spread apart a little and lose their connection. I would take the corner of the blade of a small flat screwdriver and pry the two sides of the fork into each other a little, then re-seat the connector.
                On rare occasions though one have of the fork would break off and I'd need to replace the pin. A flat bladed jeweler's screw driver (I think) can be used to pop the pin out fo the block, but as I said it's been a very long time since I've worked on one.
                -- Larry
                  I have had wires break off the back side of the elco plug. Most cases, I have soldered the wire back on. In one case i replaced the plug by soldering wires to the motherboard and making my own plug using an old table respot plug and the same pins as the C1 and C2A plugs.
                    Usually when asked about this, I point folks to google to search for ELCO. A bunch of stuff comes up
                    Regards,
                    Billy T
                    [email protected]
                      Peter
                      We've got a couple of lanes where that connector isn't quite snug enough and can cause intermittent issues. A matchbook or piece of cardboard wedged on top of the connector works like a charm.
                        It is a bad microswitch on the table. I want to say the TA2?
                          Your problem is with the table cam switches.
                          There is either a weak or sticky cam switch lever spring or an adjustment is needed.
                          Long story short.... watch TA1 and TA2.... at the end of every cycle when the table is returning to home you must CLEARLY SEE TA2 press in the switch BEFORE the table stops on TA1. If this is happening at the same time or too close together you will have ball cycle switching problems.
                          This is a common thing for ss chassis with omega tek boards.
                          Side note.... TA2/SA or SA/OS switch the ball cycles.
                            The Elco plug has nothing to do with changing the actual ball cycles.
                            MONITOR COLOR ISSUE!!
                            Pin spot is off
