Pins not on spot
  • Pins not on spot
    Does not spot pins on spot.
    table has been flagged.
    table and frame height are correct.
    table is level front 1/16th lower than the rear.
    when I do the book adjustments I adjust the spot rod to get the 1/16th gap on the screw it moves the pins almost a full inch forward.
    Could this part be on backwards causing that?
    Yes, that will do it. Pins will not spot if the part is the wrong way round.
    I gather you just recently worked on this?
    Table should be level all the way round - ideally (when empty with no pins) the back should just be slightly higher than the front, so that when filled with pins it will be level.
    Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which...
    MONITOR COLOR ISSUE!!
    Pin spot is off
    4" PVC BOW EXTENDERS
    As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
