82/70 ss omega tek
  • 82/70 ss omega tek
    1st ball sweep goes to guard, as soon as table moves sweep runs about halfway to headpin and stops.....cam switches appear correct, chassis has been moved....any ideas?
    Have you swapped out the stator on the sweep motor?
      That's an interlock John. SC opened at first guard position causing both motors to run at the same time.
      There! Try to NOT work now!
        Just so everyone knows it was an interlock related problem along with some bad pins and sockets. Thanks for all your help, just an old a2 guy trying to help.
        Qubica BES-X Lane Advertising
        Ball Damage at my wits end
        GS-X table bolts/stud
        Other that...
        1:1 shaft wear
