Odd lane pit cushion gets stuck back
  • Odd lane pit cushion gets stuck back
    Lane 3 in the center keeps having this issue where the pit cushion will get stuck back. The ball gets caught "under" the cushion, and then the pit stops and the pinsetter keeps cycling. If you push the cushion forward, then everything clears up.
    Experience: We currently maintain 12 AMF 82-70's
    My first thought would be a broken rear bounce plate.
    There! Try to NOT work now!
      Yep. That or a broken/loose bounce board mount on a side wall. Either way it sounds like time for a pit overhaul. So much fun, lol.
        Your pit wing might be bent down. You might be lucky enough just to bend it back up as a temp fix but a pit overhaul should be done as soon as
          Check the cushion shock and mounting blocks too.
            So I just put a new pit carpet in, and the bounce plate was missing some bolts. So i put the bolts back in it, and now the ball is getting stuck in the cushion. Before I put the new carpet in and re-installed those bolts, the ball would just sit up against the cushion so I'm really not sure why it's getting stuck now. I put new vibration dampeners in, repaired the bounce plate, put a rebuilt front roller in, and just put the same rear roller in.
              I assume that while you had the carpet & bounce board out you inspected the bounce board mounts, angle support & front roller studs? If those were all good and tight, then look up...
              ...to these.
              I would also check the cushion/curtain assembly for possible breakage or busted welds.
              Also, when you say the ball is getting stuck in the cushion, is it still getting stuck underneath...between the cushion and carpet? Or is the ball just stalling as it rolls along the front of the cushion?
                If the cushion facing is worn through exposing the rubber beneath, it will hold a ball against the cushion directly behind the flat gutters; usually on the ball door side. If the cushion rubber is severely worn behind the flat gutters it should be replaced as well. Both the cushion facing and the cushion rubber will only last so long.
                  So I pulled the cushion out last night (again) and looked at the weldment and it ended up that someone must've welded it in past years and they didn't weld it straight... So I replaced the weldment, cushion mounts, and shock and now it seems okay.
                    Are the cushion blocks worn? This will have the cushion move down and cause balls and pins to get stuck
                      No. The pit cushion weldment was cracked on the 10 pin side. Past mechanic tried to weld and it didn't hold up. Replaced and all is well.
                      • theykeeponrunnin
                        Pit Cushion
                        by theykeeponrunnin
                        I have a machine that the cushion is low enough the pins hit them and won't hardly go under. I know the shaker board is not too high. The links are not wore or loose either. Should...
                        12-05-2012, 02:49 PM
                      • evertonfc
                        cushion plank
                        by evertonfc
                        hi all,
                        just a small problem,on one of my lanes,when a heavy ball(12+)hits the cushion plank without hitting a pin,the ball bounces back onto the the lane,hitting the inside...
                        05-29-2005, 04:15 PM
                      • Tom1
                        Pit Cushion
                        by Tom1
                        Hi Guys I have a question; Is the the pit cushion repairably if the bolt holes are so bad they are open to the side of the cushion and several other cracks in the metal? If not...
                        07-18-2007, 02:47 PM
                      • nighthawk
                        Pit cushion shocks
                        by nighthawk
                        After completely rebuilding a cushion w/ Ed Fox's
                        kits for my a-2's one lane still has problems triggering,would bad pit shocks really hurt the triggering that much??...
                        01-23-2006, 12:34 PM
                      • Hakenson
                        "A" pit cushion
                        by Hakenson
                        On the 1/12th scale pinsetters I am making I want to make an A pit cushion and I have the pictures from the parts catalog but all that shows is the cushion but I need a picture...
                        04-02-2007, 09:28 PM
                      Qubica BES-X Lane Advertising
                      Ball Damage at my wits end
                      GS-X table bolts/stud
                      Other that...
