8270 ss chassis klixon problem
  • 8270 ss chassis klixon problem
    I currently have a side project with a SS chassis t(Omega tek board) I had to rewire.it originally had a problem of not cycling from B.E. control box.after going through all connection from both C1 and C 2 and all connection from each relay and contactors.i got it to start cycling again but now it has a problem with the OLL klixon protection for the mask lights.when the chassis is powered on .the klixon will keep popping.and I can't get 1st or 2nd ball light to change from b.e. control stepper zero.does any one with decent experience in these chassis have a good idea of where to check on the chassis.maybe its the klixon that's bad?
    If it isn't the klixon itself try looking at the heat sink and see if maybe a screw is wedged there or maybe a broken wire.
      Sure enough.i had looked into the chassis earlier and I did find an old jumper wire from one of the contactors sitting RIGHT THERE.wow. the smallest things that make the biggest difference.thank you for your input
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
