Edge Pinspotter Plastics
  • Edge Pinspotter Plastics
    What cleaners/dressings are you using on your Edge plastics - plows, o-pan, distributor pin funnel etc?
    I've noticed pins can "stick" to the plows causing 2nd guard/bin switch timeout.
    A buddy of mine was told to wipe with ArmorAll by installers.
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
