82/90 Xli trouble scores ( frozen )
  • 82/90 Xli trouble scores ( frozen )
    Hi everybody ,
    Sometime i have a little trouble on one pair , the player play normally but sometime in the game the score doesn't work ( frozen ) but my machine make the cycle normaly 1st and 2nd , i tried to reset my 3 QT but the result is the same sometime in 1 day or one week ! i work on 82/90Xli , 3Qt , bcu II , Q vsion camboard , okkio cam ! my scoring system is pro conqueror ! somebody can help me please ? Thank you very much
Bind in deck hook linkage
GS-X table bolts/stud
Other that...
