Gearbox grind.
  • Gearbox grind.
    I recently rebuilt a Westinghouse combo gearbox that I found in our parts cabinets. All the gears looked fine and the shims seemed fine. Now it makes a bit of a grumbling noise and runs a little warm. Should I be concerned?
    Take it off and drain it a little to see if the oil has discoloured from the gears grinding
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
