How to connect amp 8-90 xli with qubica f-box.
  • How to connect amp 8-90 xli with qubica f-box.
    friends i need help
    old qubica scoring system (f-box)
    how to use amf 82-90xli machine control box
    I make a connection, can you help with this?
    Is there any manual.
    Thank you.
    I examined the manual files of 82-90x
    this machine only communicates with serial communication.
    I did not find any other method of communication.
    Where can we find the cognition about this communication I was wondering
    for example:
    baud= ?
    parity= ?
    Data Bits =?
    Stop Bits=?
    how can we reach your information
    Thank you
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
