Durabowl bumpers problems
  • Durabowl bumpers problems
    I got durabowl bumpers i got one lane win u pop the bumpers up the left side wont come up. I went down and tryied to pull the bumper up but it wont stay up falls down. the right side bumpers in up and goes down okay lost thanks 4 your help ne one
    Re: Durabowl bumpers problems
    Is this an automatic setup with air driven pistons?
    Havn't played with the regular spring loaded jobs.
    But if air driven, to you hear rushing air by the lane?
      Could be a number of things which have gone wrong.
      In order to check out what the problem is, you will need to get in there and have a look. First of all remove the capping - two sections. Then unscrew the transition block at the front of the gutter. Remove the gutter securing metal plate screws also, which run down the side of the gutter section. Once removed, you can unscrew the 3 screws on the little plate, which attaches both sections of guttering together. Now you can remove the gutter section.
      Once removed you can get in and have a look at the sub opener assembly, and see what has occurred.
      Sometimes the upright arm allen screws come out, or the activator arm could be snapped, or the piston metal bracket could have broken etc.....
      Good luck.
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
