chassis problems
  • chassis problems
    I got 82-70 machines i have single board chassis and i have one chassis that win i plug it on the machine the sweep relay inside the chassie sticks in and i get a hum sound and my pit will not come on i put a good board in the machine so i no it isnt the board any help thanks
    Re: chassis problems
    What condition are the contacts and C1 pins in? What type are you using?
      Your going to need to include a little bit more info Durbing.
      What type of chassis?
      as wb stated, whats the condition of the C1 chassis pins, on the chassis side and machine side plugs?
      Have you moved this chassis to another lane to isolate the problem to the chassis or machine?
        the c1 pins look great its win i fire up the machine the sweep contact in the chassis stay ingaged and hums and the pit wont run the chassis is a mp chassis whith a single board and i use the silver c1 pins. yes i have put this chassis on another lane and still does the same thing.
          I have ran into the same problem with one of my chassis. You need to check all four of your circuit breakers, also replace the sweep contactor in the chassis. I had to replace my contactor in the chassis when I had that problem. Also check your sweep motor head boards.
            Sounds like the sweep contacts are shot. Often a MP board will run the sweep through, or drop the sweep and go through a cycle when first powered up - it's normal when they are first plugged into a chassis after power has been removed.
              ok wb8yjf i will change out the sweep contact and see what happens and i will get back to u on this thanks again to all of u
                just my luck changed the sweep contact out and now it trips the breaker dam the bad luck
                MONITOR COLOR ISSUE!!
                Pin spot is off
