Centrifugal switch installation
  • Centrifugal switch installation
    Curious to see how other people install there centrifugal switches. I can get it on with minimal to no play but other times it will split open or have to much slack in the switch and will not work properly.
    Re: Centrifugal switch installation
    New ones never seem to fit like the originals. Did you ever try Solid State Switches?
      We had one in stock that i did try, unfortunately i had a terminal to close to motor case i didn't see it arched and blew an ssr switch in the mp chassis. On the other hand the new centrifugal switches that don't fit right i have been using locktite as a fastener and it seems to be working very well so far.
        For westinghouse combos I never had much luck either but then I started craming the large disk westie BE motor on the shaft-thats tight as a frogs butt and stays put!
        70's MP/PBL/LBS,Q-Score
        Prolane Walker sport
        Help-broken Part
        Greeting all.
        Thanks for looking.
        Bolton454
        Pin Damage
        Making TDM's adjustable.
        1:1 shaft wear
