I have 82-70's and all the serial # plates on back of the P/W's have been removed. There has to be a way I can find out when they were manufactured. Is there another serial number on the frame or something to tell me when they were born? Keep in mind I still have the old style crank tube assy on the crank pulley (one with the 2 big lock nuts to hold the tube on the frame.. Not welded type.) so I know they are old, but how old?
Serial numbers and date of birth?
Re: Serial numbers and date of birth?
Usually, on my machines (different houses) I've always seen S/Ns written on the common kickbacks, might be a little hard to see, but I've always seen them.
IMHO, S/Ns are just about useless nowadays as machines have been in for so long that many S/N dependent ass'ys have been retrofitted to more current specs.
I pulled my plates during my rebuilds, but I have the numbers (for whatever reason) written on my office wall."Where are we going, and why are we in a hand basket?"
If they havent been replaced the sweep links have a casting dates, the short ones. what style tables do you have on the back row of pins are they wide open like 1-6 or is the back few inches cast closed.The dist mounting is it 3 piece or u channel bent 90 degrees?70's MP/PBL/LBS,Q-Score
Prolane Walker sport
The dist is a bent U and some of my tables have the back row cut off like you said, but some are not, only date i have found so far on any castings is the dist cam follower arm 72' I for some reason beleive they are older than 72. Only other info I have is I have seen alot of lables on some parts claiming they are from "Semenary Lanes Alexandria VA" I think that is where they were originaly. Common kickback panels? where might that number be seen? Russell Stoll I have never seen a number in that location ever.Get the facts first, THEN panic!
Dates and numbers on parts are pretty much useless as you have no idea if and how many times that part has been replaced. Also back ends and front ends could be mixed up especially if this is not the original install. My machines are a mix of just about everything you can think of, you name it and I probably have it. I have parts from B, C, and MP machines mixed up all over the place and I think I even have a couple with sweep cams from an A!
Recently I went through my machines to document the serial numbers on each of the assemblies. I did this mostly out of curiosity but also to see what issues I may run into with...
Channel: Pinsetters Brunswick A-A2
08-12-2018, 06:10 PM -
Been searching on here but couldn't find much. Im looking for the complete list of serial numbers for the 82/70 showing the evolution of the machine. I have a mix of a bunch of...10-06-2012, 06:03 AM
im trying to figure out an approximate age for our bowlmors. does anyone have a serial number list or somthing that could help determine the age? the builders plate one 1 machine...
Channel: Candlepin / Bowl-mor
04-08-2012, 08:14 PM -
I was wondering if 82,000 serial numbered pinsetters were A or A/2.
I ask this because I heard we might have some in storage that are model A's with this serial ...-
06-16-2011, 10:00 PM -
I have several solenoids on our A/2's that has bent mounting plates, these are the offset plates which are made out of thin sheet metal. They are bent from ex pinchaser think...
03-03-2004, 12:36 PM -
Upgraded Motor Contactor
C1 Pinout drawing
Finished the C1 drawing.
Thanks Felix.
If you see any...
Thanks Felix.
If you see any...
