VDB battery
  • VDB battery
    Has anyone replaced the coin battery in a VDB? If so how and what battery did you use?.
    I replaced a copy of mine from my VDB 93s. I got them from Jamie at Stahls.
      If you look they are just watch batteries and they have a number on them it will be cr#### and you use an exact knife to pry old one off and solder new one back in its place. Make sure you sand the battery where your going to solder it so you get a split connection
        The battery is a Panasonic CR2330 3V.
        KM
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
