Stumped with another chassis problem!
  • Stumped with another chassis problem!
    82-70 mp single board chassis. I've got a problem with sweep drift on 1 of my chassis. The chassis used to have the white cube style contacts that I absolutely hate. I originally that the contact was the problem since I've had this issue with several other contacts of this style. I have been replacing them with the solid state contacts from bowltronics. I put a brand new SS contact on the chassis and still having drift issues. Replaced every bit of wire coming from contact to C1 plug and new pins across C1 plug. What am I missing. What else in the chassis can cause a sweep drift. Problem follows the chassis before and after contacts were replaced. Also I'm still learning these chassis so please be as detailed as possible in explaining your thought. Thanks!
    git-R-done
    Will another chassis on the same lane resolve the sweep coasting issue?
    Will putting the "bad" chassis on another pinspotter cause that sweep to coast?
      It's a chassis problem no matter what lane I put it on it happens. The problem follows the chassis.
      git-R-done
        Did you try the replacement SS contact in another chassis? Or was it tested and known good? I had too many issues in general with new parts so I always question them
        All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
          The M2 cube and it's socket can cause drift,the sweep start circuit goes through it.
          70's MP/PBL/LBS,Q-Score
          Prolane Walker sport
            Nasty M2!!!
              It was a brand new out the box contact.
              git-R-done
                Can you replace the pins of the socket or does the entire socket need replaced?
                git-R-done
                  The entire socket must be replaced.
                    Just because it is new out of the box does not mean it is good. Try it in another chassis to make sure.
                      Exactly my point. I second this. I had numerous brand new parts right out of the box that were bad.
                        I have been able to change out bad socket pins as long as the plastic socket is not burnt,they have spares left over that were not used.
                        Preventative Maintenance - A Jets A2 - Elevator & Pits
                        All this work just to clean under the elevator !!??? LOL A friend is replacing a number of his elevators as the left hand triangle plate brackets are breaking. Rather than...
                        Preventative Maintenance - A Jets A2 - Ball Wheel Belt Question
                        A friend was looking at his ball wheel belt which stated it was 208" long, (Pic 1). He was pretty sure that it is a B205 belt which should be 205" long. The answer...
                        MONITOR COLOR ISSUE!!
                        my appologies if Ive posted this in the wrong area, this is my second post on this site, Ive got a 10 lane center ( 5 pairs ) and on lanes 3&4, I am having a problem with...
                        Pin spot is off
                        I'm currently working at a 38 Lane center. Of those 38 lanes only a few are having this issue.
                        I'm currently trying to get all the lanes to have perfect pin spots...
                        Idler shaft
                        One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
