90XL cable for Manger control unit
  • 90XL cable for Manger control unit
    Does anybody know where I can find a cable forsale used to program the 90XL chassis? It looks like a network cable got connects the chassis to the manager control unit.
    I know the pinouts on both ends, but you need an SDL connector for the output of the MCU on the bottom. I think its a type 'E' SDL connector, the other end is a standard DB9 for the chassis RS485 IN - available at Radio Shack.
      Ted- Do you have the pinout diagram?
        Sent you a PM.
        Bind in deck hook linkage
        GS-X table bolts/stud
        Other that...
