omega tek mk 70 and chassis
  • omega tek mk 70 and chassis
    ok guys, what in my chassis, is not required if running an omega tek mk 70 board
    if i don't need certain items, can i directly remove them, or are there a few tricks to it all.
    Re: omega tek mk 70 and chassis
    The aux pc board can be removed...there are other items that can also be deleted however electronics are not my forte!
      further investigation tells me that the 3 capacitors are no longer used as well as the pindication triac, but can i remove these wires from the chassis, or is there a trick to it all
        Craig please contact our newest member or just click on there BANNER STAHL'S
          Sounds like a big waste of time. What are you going to gain by this???
            i thought that would have been simple
            less parts, less possibilities
            Qubica BES-X Lane Advertising
            Ball Damage at my wits end
            GS-X table bolts/stud
            Other that...
