odd problem
  • Guest's Avatar
    switch b
    by Guest
    hey guys im a learnin on the 98's just ask Imitchel lol. but anyway on lane 24 tonight had a machine that kept blacking out after the 10 pin only would be picked up. i would...
    03-13-2001, 12:54 AM
  • vinson
    Mechanics Tip
    by vinson
    Here's a tip for you,
    before installing a start switch -micro switch . Wrap a it a couple of times with electrical tape before installing it. That way the switch will last...
    02-11-2002, 12:35 AM
  • Sal
    Bypass Switch
    by Sal
    Does anyone know where there is a wiring diagram for the bypass switch in the rear of the wire channel next to the mechanics switch?
    Thanks.
    05-14-2003, 02:02 AM
  • Bobbie_Bees
    Pinholder Microswitch
    by Bobbie_Bees
    Going through the machines at Lucky 9 Lanes here in Richmond, BC, I've noticed a few things with the micro switches in the pinholders.
    The original micro switch is...
    02-09-2018, 12:24 AM
  • redclutter
    Y switch
    by redclutter
    Can someone give me some guide lines on how the y switch is supposed to be adjusted. Meaning what am i looking for forward to back, side to side,and how the ball tracks should...
    10-13-2010, 10:09 AM
Help-broken Part
Greeting all.
Thanks for looking.
Bolton454
Pin Damage
Making TDM's adjustable.
1:1 shaft wear
