Crack on frame guide shark
  • Crack on frame guide shark
    Guide frame shark crack all 16 lane
    JLK
    Re: Crack on frame guide shark
    All 20 had cracks here, I had to remove all sharks weld up and replace, rebuilt all sharks while I was at it, there is a 2 year warranty on sharks, mine were 7 years old and Brunswick offered to cover 30 % of replacement cost and I would pay shipping.
      a seen you have put a spring on the shock on the ball cushion is that affective and does it help on the wear and tear on the shock
        what GS-Series is this 92??
          Mine are GSX installed in 2001
            I thought all cushion shocks were supposed to have the spring. It helps place the cushion at the right position from the ball door after impact.
              Hey, where did you get those overflow chutes from ? We just have the black plastic ones at our alley. Those with the carpet like material seem like they would cut WAY down on pin washing and free up chasers to do other things ...
              'Bring a roll of duct tape with ya' ... we'll get er' straightened out !
                I keep a fully rebuilt shark and 4 spare side frames for when I decide to have a welding day. I also weld and remake the hole where the back pulley goes because if this hole starts to wear out it will give u uneven belt wear
                Detector Rod Adjustment
                The New Brunswick NXT
