Chain Tension
  • Chain Tension
    Just wondering if the chains that are on either side of the machine are supposed to have the same tension.
    The one on the pin 10 side is very tight and the one on the pin seven side has about 2" play in it.
    I've check for level and everything is spot on. Any ideas if i need to tighten the pin 7 side (stroke limiter)
The New Brunswick NXT
