Pinsetter not operating
  • Pinsetter not operating
    Hello. We recently purchased some GS Pinsetters. The machines seem to be a mix of 98 and X parts, but either way we were successful in restoring all of them. Last night we successfully got the last of the lanes to function properly, however, when we shut the machines down for the night and came back in the last machine will no longer operate.
    The problem we are having is that when we turn the pinsetter on you hear the ball accelerator kick on but none of the other motors. When we manually turn the mptprs on at the contactors all motors fire up and do what they are supposed to, but npt when we turn the whole machine on?!?! It will run (with the accelerator running) for a moment and then kicks us an EJ ERROR. The pinsetter it shares the CPU with operates normally so we more or less ruled out the CPU. The IO board was switched out with another and we get the same issue. We are stuck and looking for help asap. Thanks in advance!
    seems there is a jam on the elevator one of the shovels may of got caught reverse the elevator using the t band drive belt and see if that will allow the shovel to unlodge and then try running the pinsetter again
    im never wrong just askme
      Yes, manually try to move the Tband in its normal direction; pull off the elevator cover and make sure the EJ switch is being activated by the shovel wheel -- if the tband/elevator move freely manually, the switch tang may be bent and not getting hit as the shovel goes by -- or the wire is pinched in that cable.
        Is the masking unit switch on?
        Bobbie Bees
          image_8745.jpg If you get a error in the 90s, there are several states that will prevent it from coming on. Here are the 90 codes and causes.
            Check the chain on the elevator a link pin might be out just enough to cause the elevator jam .
                did you find the problem?
                John
                  Do you have any sort of emergency stop or other safety cut out feature that may still be activated. Our machines accelerators come on but nothing else (pit light etc) and when try to reset will just throw out an EJ even if nothing wrong with elevator.
                  Pins getting gouged
                  Need Pinout for J2 & J22 (Masking unit)
                  Hi Guys!
                  I need some help. We're installing custom Masking units at a new location in PDX. Our sister center in Beaverton, OR has ZOT/ Horizon Ball indicator PCB's for the...
                  Cracked Moving Deck
                  I have a couple of pinsetters that have a cracked moving deck and I would like to replace them before leagues start. I have some spares that I can put in but I don't know how...
